I am trying to replace the 40G Ethernet IP by the 100G in a new FPGA that I just bought (FPGA is stratix 10 : 1SX280HU2F50E1VGAS).
The link is not coming up, I am looping back 2 Ethernet ports of the same FPGA.
When I access the Avalon-MM interface, all the registers that I try to read return the value :
0xdeadc0de.
I am guessing it is not a register clock issue (as I wouldn't be able to read anything), nor a reset issue (as some statistics counter value would be 0x00000000).
Do you have any idea of what could be happening here?
HI,
One of the possibility is you are reading the reg from invalid/incorrect memory region.
You may want to check the reg address memory mapping in your design again.
dlim
HI,
dlim
Hi Dlim,
actually I noticed that I had forgotten to enable RS-FEC in the IP, since I enabled it, my design is not able to pass fitter.
Fitter reports "cannot place node [...] for hundreds of lines.
My design is very simple and almost empty (only 10% of FPGA logic is used), it contains :
4 times :
[100G ethernet IPs] + logic to answer to an ARP or ICMP request (ton answer PING).
I am guessing the design is not constrained enough, I have generated the low latency 100g ethernet FPGA ip example design, and I got inspired by the .sdc constrain file provided in it. Basically :
for { set i 0 } { $i < $x100g_count } { incr i } {
set THIS_RX_RS_CORE_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|RXIOPLL_INST.fecrxpll|alt_e100s10ex_iopll_rx_outclk0]
set THIS_RX_RS_CORE_NCK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|RXIOPLL_INST.fecrxpll|alt_e100s10ex_iopll_rx_n_cnt_clk]
set THIS_TX_RS_CORE_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|TXPLL_IN.TXFPLL_INST.tx_pll_gen.fectxpll|clkdiv_output_div1]
set THIS_RX_CORECLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|rx_clkout2|ch1]
set THIS_TX_CORECLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|tx_clkout2|ch1]
set THIS_REF_CLK [get_clocks cg_ref[$i]]
set_clock_groups -exclusive -group $THIS_TX_CORECLK -group $THIS_RX_CORECLK -group $THIS_TX_RS_CORE_CLK -group $THIS_RX_RS_CORE_CLK -group $THIS_RX_RS_CORE_NCK -group $TRS_DIVIDED_OSC_CLK -group $STATUS_CLK -group $REF_CLK
# set false path from PMA fifo flags' clock to clk_status (ex_100g_inst|ex_100g_inst|alt_s100|csr|eio_flags_csr[*])
for {set chNum 0} {$chNum < 4} {incr chNum} {
set RX_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|rx_pcs_x2_clk|ch$chNum]
set TX_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|tx_pcs_x2_clk|ch$chNum]
set_clock_groups -exclusive -group $RX_CLK -group $STATUS_CLK -group $TRS_DIVIDED_OSC_CLK
set_clock_groups -exclusive -group $TX_CLK -group $STATUS_CLK -group $TRS_DIVIDED_OSC_CLK
Do you see any constraint missing here?
Hopefully, now your problem is solved. Let me know if you need any help yet because i handled the same issue few days ago.
Hi Aleytu,
no my problem is not solved... Can you let me know how you handled it?
Hi all, problem is solved.
For 0xdeadc0de : I had an error in my addressing register, I was reading a wrong address.
For the placement : I updated to Quartus 20.2
