FPGA Intellectual Property
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
5917 Discussions
MAX10 A/D sampling rate
ZBien
In MAX10 Analog to Digital Converter User Guide on page 17 the folowing is denoted:
The maximum cumulative sampling rate in normal sampling mode is 1 MSPS.
So if I use 9 A/D inputs in normal mode at maximum rate, each analog input will be sampled at 1M /9 rate?
If I'm using the temperature sensing mode + 8 analog inputs, still each input will be measured at 1M/9 rate ( except the tempertaure)? or each analog input will be measured at 50khz rate?
Zvi
YuanLi_S_Intel
Hi Zvi,
Please find my response below:
[1] So if I use 9 A/D inputs in normal mode at maximum rate, each analog input will be sampled at 1M /9 rate?
A: Yes as MAX10 uses SAR ADC.
[2] If I'm using the temperature sensing mode + 8 analog inputs, still each input will be measured at 1M/9 rate ( except the tempertaure)? or each analog input will be measured at 50khz rate?
A: It is 1Msample /8 because you have 8 normal analog input pin (which Cumulative samples) in normal mode and ADC switchover for TSD measurement at 50 KHz.
Thank You
