FPGA Intellectual Property
6669 Discussions
Marvell 88E1111 PHY question
I am using cycloneIII board with Marvell PHY RGMII interface. After searched around forum, I found suggestions that in order to receive frames successfully, the bit7 of mdio register 20 should be set to 1 (default is 0) to add delay 2ns to rx_clk. Is this always the case for Marvell 88E1111 PHY or it's board dependent?
Thanks!
No, it depends on how you specify the timing requirements on the FPGA side.
