FPGA Intellectual Property
6670 Discussions
Module avalon mm slave and master
I need a example of a module avalon mm that is master and slave.
Or how can I build one.
Hi leobenedette,
Would you mind to further clarify if you are looking for any specific application's AVMM master and slave? You could try to search through the Altera wiki page for embedded design example to see if can find any specific design example that suit you:
http://www.alterawiki.com/wiki/category:embedded_design_examples
http://www.alterawiki.com/wiki/category:embedded_hardware_and_hardware_tools
http://www.alterawiki.com/wiki/category:embedded_processing
http://www.alterawiki.com/wiki/category:embedded_software_and_software_tools
--- Quote Start ---
--- Quote End ---
As I understand it, the transceiver toolkit design example is always using JTAG master to interface with other slaves through AVMM. Probably you could try to have a look on how the design is constructed in Qsys to get further idea.
You can get the design examples at https://www.altera.com/content/dam/altera-www/global/en_us/others/support/examples/download/transceiver_toolkit_13_0sp1_qar.zip
hi leobenedette,
You could try to search through Altera wiki (http://www.alterawiki.com/wiki/special:categories) and Altera ref design page (https://www.altera.com/products/intellectual-property/reference-designs.html) to see if can find any design for reference.
