FPGA Intellectual Property
6669 Discussions
NCO v 11.1 not working
I have Quartus v11.1 Build 216 and generate NCO by his Wizard, generating include Simulation Model and Netlist. Then i try simulate this in Altera ModelSim and NCO not working. I use original TB generated by wizard and NCOout make only "U" I expected sine wave, not U. Where I made mistake?
Thanks for any help.
Did You initialize Your signal values?
--- Quote Start ---
--- Quote End ---
Yes, they should. I use to initialize "ALT_NCO_tb.vhd" which be automaticly generate with NCO core. Or do You mean somethin different? I attach TB (ALT_NCO_tb.vhd.txt)
initialize all signals, e.g.:
signal reset_n : std_logic := '0'; signal sin_val : std_logic_vector (MPR-1 downto 0) := (others => '0');
--- Quote Start ---
--- Quote End ---
I paste this lines into my TB. It initialize zero value but NCO still not working. Initialize in attach.
You have to do this for ALL signals. But anyway, I believe the problem is somewhere in other place.
yes, initialization do only the "0" from the "U", but not from NCO sinusoidal wave
There may be other problems, too, but setting reset_n to '0' will keep the NCO in reset. You should only pulse it low.
We have right, the problem was some other. I forgot attach source file generated from BDF in NativeLink settings.
I overlooked ModelSim's Warning: (vsim-3473), that is already described here.
thx for help
