FPGA Intellectual Property
6670 Discussions
Need Help For Learning Sd Card Ip Core
Hi, I want to make a SD CARD SPI MODE Host controller. I tried to make it using vhdl code only. But in the middle of it , I realized that it was to complex without using SOPC builder and NIOS II. Since ,I'm new using iP core. I don't know how to start.
I'm already search in the web for any example SD CARD IP Core, but 'till now it's all not free :( . Please if anyone can help me ?
may be this can help you:
http://www.niosforum.com/pages/forum.php?cat_id=5
Regard
Luca
when i build the project in the NIOS IDE,there are some errors:
**** Build of configuration Debug for project hello_world_1 ****
make -s all includes
Linking hello_world_1.elf...
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.text+0x54): In function `alt_sys_init':
system_description/alt_sys_init.c:92: undefined reference to `sd_controller_dev_init'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1144): undefined reference to `sd_open_wrapper'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1148): undefined reference to `sd_close_wrapper'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x114c): undefined reference to `sd_read_wrapper'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1150): undefined reference to `sd_write_wrapper'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1154): undefined reference to `sd_lseek_wrapper'
/cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1158): undefined reference to `sd_fstat_wrapper'
collect2: ld returned 1 exit status
make: *** [hello_world_1.elf] Error 1
Build completed in 85.875 seconds
How can I solve this problem?
Thank you.
Hi quray,
sd_controller_dev_init'sd_open_wrapper'sd_close_wrapper',etc Is it a function ?
If it is a function please check Have you already include the .h file that describe the function ?
I'm new in here but i'll try my best to share my experience.:)
Than you very much.I have solved this problem.
sopc builder in Quartus 8.1 is different from Quartus 6.1 .
in \neek_alternate_sd_card_controller\sd_card_controller_component\SD_Card_Controller_SPI\HAL\src
create component.mk ,and add # This file generated on 2006.03.22.10:57:43
C_LIB_SRCS += sd_controller.c\
fat.c\
fat_file.c
ASM_LIB_SRCS +=
INCLUDE_PATH +=
# end of file
in this file.
http://www.cnblogs.com/oomusou/archive/200...mponent_mk.html (http://www.cnblogs.com/oomusou/archive/2008/12/06/ip_component_mk.html)
hi,Luca Olivero, u give the web can not connect,i also want to learn about how to use the sd card.
Hi,I P,
can u post me some files about the sd card,i also use the sopc builder to use the sd card. thanks!
Hi,I P,
