hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
FPGA Intellectual Property
6558 Discussions
Nios development board excalibur kit Altera
Giovanni3
Salve, ho a disposizione la Nios board dell'excalibur kit Altera, avrei bisogno di programmare l'fpga Apex EP 20K200 con flash memory Amd AM 29LV800BB, ma ho a disposizione nios 2 flash programmer e non me lo fa fare. È disponibile Nios SDK shell? Dove posso trovarlo?
KellyJialin_Goh
Greetings and welcome to Intel's forum.
Could you kindly translate your question to English as it will be difficult for me to understand your question properly.
Thank you.
Kelly
KellyJialin_Goh
You may find the SDK information on NIOS II command shell with this link here: https://www.intel.com/content/www/us/en/docs/programmable/683282/current/starting-the-nios-ii-command-shell.html
Thank you.
Kelly
Giovanni3
I need to nios sdk shell and not nios II. Is it available nios sdk shell?
KellyJialin_Goh
You will need follow this link to generate BSP: https://www.intel.com/content/www/us/en/docs/programmable/683689/current/application-12184.html
1)Click Generate BSP. Make sure the BSP generation is successful.
2)Close the BSP Editor.
I will attach a picture for your reference on the button to Generate BSP.
Thank you.
Kelly
KellyJialin_Goh
Any updates from your side? Do you need any further clarification from my end?
Thank you.
Kelly
Giovanni3
I didn't solve, i need the quartus version which contains Nios SDK shell
KellyJialin_Goh
Thank you.
Kelly
KellyJialin_Goh
May I know the Quartus version you are using?
The devkit you are using is actually quite old and will have to check if it is still supported from our end.
Hope to hear from you soon.
Thank you.
Kelly
KellyJialin_Goh
Thank you.
Kelly
KellyJialin_Goh
Any updates from your side? Do you need any further clarification from my end regarding your issue?
Thank you.
Kelly
KellyJialin_Goh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
