FPGA Intellectual Property
6670 Discussions
No response when alpplying write on avl_mm port when using generic serial flash interface IP
Kavin
when I apply memory write with generic serial flash interface IP,there is no response on QSPI physical pins,but these pins response correctly when applying write enable or memory read.
Kavin
Hi
Thanks,the problem is solved.In my design ,the burstcount default value is 0 and i forgot to change it's value.
Kavin
what is the right step to apply  memory write?
YuanLi_S_Intel
You may refer to the user guide at below for the steps to perform write operation:
https://www.intel.com/content/www/us/en/programmable/documentation/tkt1520669802999.html#aog1522582064422
Thank You
Kavin
Hi
YuanLi_S_Intel
I am glad it is solved now
