FPGA Intellectual Property
6670 Discussões
On-chip FIFO in Qsys - How to read/write from/to an SCFIFO?
Colaborador honorário II
1.410 Visualizações
Hello everyone,
I am implementing an MM to MM FIFO in single-clock mode under Qsys.
Now, I try to understand how to read and write from it.
The API gives the following code for the read and write functions :
Prototype: int altera_avalon_fifo_read_fifo(alt_u32 read_address, alt_u32 ctrl_address)
Parameters: read_address—the base address of the FIFO read slave
ctrl_address—the base address of the FIFO control slave
Prototype: int altera_avalon_write_fifo(alt_u32 write_address, alt_u32 ctrl_address, alt_u32 data)
Parameters: write_address—the base address of the FIFO write slave
data—the value to write to address offset 0 for Avalon-MM to Avalon-ST transfers, the value to
write to the single address available for Avalon-MM to Avalon-MM transfers. See the
Avalon Interface Specifications for the data ordering.
I implemented a FIFO without any status port (the datasheet says it is optional).
But my question is : how to use the read and write functions if I don't have such ports?
It seems like the needed "ctrl_address" refers to this type of ports.
I could add such a csr port, but on an SCFIFO, it is allowed to do so only on the input side (only the in_csr port is allowed).
...So it seems like I can at best only write and not read anything.
Does someone have a clear explanation for me ?
Thanks a lot,
Arkady
0 Respostas
Responder
