FPGA Intellectual Property
6669 Discussions
PCIE HIP msi_request occurring before the corresponding avalon stream
ASvir2
Hi everyone,
I'm using pcie hip in a multifunction design (I have 2 functions).
Due to difference in propagation delay of the Avalon stream TLPs and the msi interrupt requests in the app layer of my FPGA design, there's sometimes a situation where app_msi_request reaches pcie HIP before the corresponding Avalon stream TLP (it's a matter of ~20 clk).
Could this be an issue for the pcie hip?
Thank you.
Nathan_R_Intel
Hie,
Could you help clarify your question a little more. Are you saying the write TLP is ~20 clock cycles after app_msi_req? This could be dependent on when app_msi_tc and app_msi_num has a valid window.
Hence, this might not be entirely dependent on the PCie HIP.
The following wiki side has some timing diagram related to app_msi_req.
https://fpgawiki.intel.com/wiki/Handling_PCIe_Interrupts
Nathan
