FPGA Intellectual Property
6669 討論
PCIe Hard IP Issues With EFI
MZORAN
初學者
653 檢視
I have a fpga design using the Intel Hard IP for PCIe on the Intel Cyclone 10GX development board.  The design works well when using traditional BIOS booting, but I'm seeing a very large number of Avalon MM bus issues when booting with EFI. Reads from fpga registers often return trash in the EFI case. Any ideas what the problem may be?
Quartus 22.1 Pro.  I've also tried Quartus 21.4 and have the same issue. In both the traditional BIOS and EFI cases I'm seeing the physical address of the PCIe card being mapped in the 32bit address space of the PC host.  The PC host is an Intel PC running 64 bit Linux.  Same FPGA image in both cases.
0 積分
1 回應
Wincent_Altera
629 檢視
Thanks for reaching.
There is the same question has been answered in another community forum
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Intel-PCIe-Hard-IP-Trouble-With-EFI/td-p/1384428
Hence, I will close this loop as a duplicate. However the community users will continue to help you on this thread. Thank you
WeiChuan_C_Intel
回覆
