FPGA Intellectual Property
6669 Discussions
PCIe Master does not receive any data
I am using the Altera PCIe IP core with the Avalon-MM interface. The FPGA is acting as master and requests a read. In SignalTap I can see that it puts the address and asserts the read enable signal. However, it then receives a Wait Request signal. This signal is never deasserted.
On the PC side, I am using the Jungo WinDriver and Windows XP. When the FPGA is master and is performing a write, there is no problem.
Any thoughts as to what could be the cause?
Thank you,
$g
I started a topic about a similar issue a while ago:
http://www.alteraforum.com/forum/showthread.php?t=31439
This is a very similar issue. Or possibly the same. Which type of motherboard do you use for testing?
Please let me know if you find something. I will do the same.
Istvan
