FPGA Intellectual Property
PLC FPGA IP
pkulk10
We are looking for FPGA IP for PLC controller to communicate IO modules with PLC controller over ethercat protocol. We need FPGA based solution like IP. Can you provide any solution on this requirement?
Parimal
Deshi_Intel
Unfortunately we don't have any PLC over Ethernet solution support for Intel FPGA product.
Intel FPGA Ethernet solution is typically Ethernet protocol solution that covered until MAC layer.
You can check out the list below on supported Ethernet IP solution from Intel FPGA. Thanks.
dlim
