FPGA Intellectual Property
6670 Discussions
Periodic Pulses Pattern
sdb
I'm a new Verilog programmer and still rely on examples to write code.
I didn't find any example of what I need.
I need to generate two pulses periodicaly like this following schema:
clk is the base of the period (pulse every 8 ticks for example).
pulse1: rises 3 ticks after positive edge of clk and falls 2 ticks later.
pulse2: rises 4 ticks after positive edge of clk and falls 3 ticks later.
I'd like also generates the pulses for a limited number (N) of periods, 1 ≤ N < ∞.
I suppose I have to use temporisation conditions (#t) but didn't success to synchronize them to posedge of clk.
Thank for your help.
Nurina
Thank you for using Intel Communities.
Please allow some time while I investigate.
Nurina
Nurina
Are you trying to do this for simulation only? Are you trying to have a testbench to show this behaviour?
Can you share what you currently have?
Nurina
sdb
Thank you to your answer,
Yes it is for a testbench only. I have no result because I didn't find how writing the code to obtain the desired result.
Best regards.
Daniel
Nurina
Can you attach the code you have written so we can work from there?
Nurina
sdb
Here are the expected periodicaly outputs of the test bench:
I tried this code. What is the problem?
`timescale 1us/1ns
module Pulses(clk, pulse1, pulse2);
output clk, pulse1, pulse2;
wire c, p1, p2;
initial
begin
  c = 0;
  p1 = 0;
  p2 = 0;
  repeat(1000)     //1000 cycles repeated
  begin
    #0 c = 1;
    #1 c = 0;
    #2 p1 = 1;
    #1 p2 = 1;
    #1 p1 = 0;
    #2 p2 = 0;
    #1 ;
  end
  assign clk = c;
  assign pulse1 = p1;
  assign pulse2 = p2;
end
endmodule
Thank you
Nurina
That doesn't look like a testbench. How are you simulating this? Are you using ModelSim/QuestaSim?
I tried using QuestaSim and managed to get the output you want.
First of all, a testbench shouldn't have any ports declaration -> module Pulses(clk, pulse1, pulse2);
It should be empty like so -> module Pulses ();
And I don't think you can use assign in testbench.
Please refer to the verilog files I'm attaching. periodic_pulses.v is the top verilog file in your Quartus project and periodic_pulses_tb.v is the testbench.
Follow the steps here to compile and run simulation, it should be the same for Quartus Lite:
QuestaSim: https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
ModelSim: https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/simulation-quick-start.html
Nurina
p/s: If any answer from the Intel Support is helpful, please feel free to provide rating with 4/5 survey on the support provided.
FvM
apart from the point that outputs have no purpose in a testbench, the problem in your original code are of different kind.
Assignment must take place outside the initial statement.
`timescale 1us/1ns
output reg clk, pulse1, pulse2;
reg c, p1, p2;
initial
begin
c = 0;
p1 = 0;
p2 = 0;
begin
#0 c = 1;
#1 c = 0;
#2 p1 = 1;
#1 p2 = 1;
#1 p1 = 0;
#2 p2 = 0;
#1 ;
end
end
assign clk = c;
assign pulse1 = p1;
assign pulse2 = p2;
endmodule
