FPGA Intellectual Property
6670 Discussions
Picture in Picture
Sorry if this is a dumb question .... I can't figure out how Picture in a Picture should work. Assuming I take an image, clip it to just grab a part of the picture and then scale it, how do I place it on a given location of the output picture (with, I assume, the alpha mixer)?
I think that the clip function isn't completely obvious to me. Assume the input of a 100x100 image that is clipped with a rectangle of 30x30 starting at 10,10 do you end up with a 30x30 image or a 100x100 with all pixels outside the 30x30 clip area as black???
Phil
1 - Yes, the mixer will position all layers on top of the background layer. So, the background layer should contain your full-size video, then layer 1 would contain the foreground image.
2 - The clipper keeps a rectangle of video. so your 30x30 rectangle would result in a video output of 30x30. The remainder of the picture will be removed entirely.
Jake
Thanks for the quick response! So then, is there a function in the VIP that would put that 30x30 at a given location of a larger image so that the pinp could be in the top right or top left or whereever??
Thanks again,
Phil
Yes. The mixer is the block that provides that function.
Jake
You are right and its work very fluently.
