FPGA Intellectual Property
6669 Discussions
Problem With Compilation
I recently install dsp builder v9 in my computer, but i hve problem with compilation.......when i try to compile a program with singal compiler an error occured........
Matlab error
Unable to obtain dsp builder license.Please check that your LM_LICENSE_FILE envirionment variable set to a valid lisence file or Lisence server.LM_LICENSE_FILE is currently "C:\altera\90sp2\quartus\license.dat
I have a valid license for quartus and dsp builder and i don't understand why this happened. I use quartusv9.0sp2 and matlab2009a.Can anyone help?
check your license.dat for the following line:
FEATURE C4D5_512A alterad 2009.10
the 2009.10 is the maintenance date which corresponds to the newest version of the DSP Builder you can run.
No my feature line not expired and i can see from matlab command window that my license is valid.
