FPGA Intellectual Property
6670 讨论
Problem erasing a Micron Flash using the Generic Serial Flash Interface IP
FHint
新分销商 II
1,853 次查看
I am using the GSFI to access a MT25QU256ABA flash in order to write and erase FPGA images, that will be loaded via the Remote Update IP.
Writing and erasing JIC files with the Programmer/SFL Design works fine as well as writing via the GSFI.
The problem comes up as soon as I try to erase multiple sectors. Erasing the first sector works fine:
1) Set the command register to 0xDC (-> 4 byte erase)
2) Set the address register to the base address of the sector
3) Start operation
Then I start to cyclical read the flag status register (command 0x70) and check whether Bit 7 equals 1. After about 7 ms the Bit is set to 1, the sector is erased and I proceed to the next sector.
But this time, after doing the 3 steps mentioned above, the READY Bit in the flag status register is immediately set but the sector is not even erased. As if by setting the command and address and starting the operation the IP core wouldn't even change it's state to busy. Did the core "lie" to me when it changed it's state to READY after 7 ms?
This makes it hard for me to implement a routine that erases multiple sectors at once, because I don't know when the flash is ready for me to proceed to the next sector. Is there no other way than to add a wait time? Why does the READY Bit only work for the first sector? I have even tried to do the clear flag status command (0x50) after I have gotten a READY = 1 but that didn't help either.
Has someone else come accross this problem?
Thank you very much in advance!
Best Regards
0 项奖励
1 解答
JohnT_Intel
员工
1,840 次查看
Yes, you need to performed it to before every erase.
在原帖中查看解决方案
5 回复数
JohnT_Intel
员工
1,847 次查看
H,
May I know if you performed write enable to the flash?
FHint
新分销商 II
1,844 次查看
yes, I performed a single Write Enable (command = 0x06) to the flash before the first Sector Erase.
Do I need to do that previous to every erase?
0 项奖励
JohnT_Intel
员工
1,841 次查看
FHint
新分销商 II
1,835 次查看
thanks a lot!
But I still wonder why it worked with a wait time of about 100 ms without repeating the Write Enable.
0 项奖励
JohnT_Intel
员工
1,831 次查看
You will need to check the Micron Flash specificaiton.
0 项奖励
回复
