FPGA Intellectual Property
6670 Discussions
Problem running pin_assignments.tcl script with uniPHY DDR3 controller
I'm experiencing some problems with SoPC builder and quartus 11.0.
Why SoPC builder and not Qsys ? Because I use an IP that is'nt yet avaible with Qsys...
I did a very simple project with SoPC buider :
For a Stratix IV device :
- Nios II processor
- DDR3 controller with uniPHY
Building the system with SoPC builder is OK. Analysis & Synthesis are OK.
After that I did : Tools -> Tcl scripts, then I selected and launched <>_pin_assignments.tcl script.
Here is the log (tcl console) :
ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object. while executing "get_node_info -cell $node_id" (procedure "is_node_type_pll_clk" line 2) invoked from within "is_node_type_pll_clk $pll_output_node_id" (procedure "get_input_clk_id" line 2) invoked from within "get_input_clk_id $pll_ck_clock_id" (procedure "ddr3top_p0_get_ddr_pins" line 237) invoked from within "ddr3top_p0_get_ddr_pins $instname allpins" (procedure "ddr3top_p0_initialize_ddr_db" line 13) invoked from within "ddr3top_p0_initialize_ddr_db ddr_db" (file "D:/dev_fpga/test_ddr3_11/sopc/ddr3top/altera_mem_if_ddr3_phy/ddr3top_p0_pin_assignments.tcl" line 191)
If someone has an idea... Similar projects worked well with the same procedure with Quartus 10.1...
Thank you.
if you built your design in older Quartus and migrated the project
there might be changes in the generated top level
look over the connections
I create the project with Quartus 11. It isn't a migrated project ;)
I have exactly the same problem except that I am using Qsys.
But I have the same error.
Need help please!
Cheers,
C.
Ok, It's not just me :cry:.
I switched back to quartus 10.1...
I also have exactly the same error with Q11.0 UniPhy DDR3.
Making me very sad...
BTW, I also get a whole bunch of critical warnings before this event all roughly similar to :
Critical Warning: Could not find pin of type ck_pins from pattern uniPHY_group_inst|master_phy_top|uniphy_master_inst|p0|controller_phy_inst|memphy_top_inst|umemphy|uio_pads|uaddr_cmd_pads|clock_gen[*].uclk_generator|pseudo_diffa_0|o
but with various different paths.
Aha - I think I have found it. It is basically the same problem as described in solution rd05232011_576. (Search for this on the Altera website). I would post a link but the forum won't let me :-(.
It is not EXACTLY the same problem, but I have changed the std_logic_vector(0 downto 0) to std_logic in the component definition for the verilog sub-entity, and changed the mappings to the form:
mem_ck => mem_ck(0).
I hope this helps
Did you succeed to run the pin_assignment.tcl script without any errors?
Yes. It ran without error after the changes although I still receive one critical warning that I am having a look at (there were 9 before the changes).
Thank You, It works.
- Replace, std_logic_vector (0 downto 0) by std_logic for :
mem_cas_n
mem_ck
mem_ck_n
mem_cke
mem_cs_n
mem_odt
mem_ras_n
mem_we_n
- Replace, for all the above signals, mem_(0) by mem_x
Here is an example of a Python script which can do all the job for you, just replace the path and the name of your top level entity generated sy SoPC builder :
f = open('./src/sopc/your_sopc_top_level.vhd') text = f.read() f.close() new_text = text.replace("mem_cas_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cas_n : OUT STD_LOGIC;") new_text = new_text.replace("mem_ck : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ck : OUT STD_LOGIC;") new_text = new_text.replace("mem_ck_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ck_n : OUT STD_LOGIC;") new_text = new_text.replace("mem_cke : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cke : OUT STD_LOGIC;") new_text = new_text.replace("mem_cs_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_cs_n : OUT STD_LOGIC;") new_text = new_text.replace("mem_odt : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_odt : OUT STD_LOGIC;") new_text = new_text.replace("mem_ras_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);", "mem_ras_n : OUT STD_LOGIC;") new_text = new_text.replace("mem_we_n : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)", "mem_we_n : OUT STD_LOGIC") new_text = new_text.replace("mem_cas_n(0)", "mem_cas_n") new_text = new_text.replace("mem_ck(0)", "mem_ck") new_text = new_text.replace("mem_ck_n(0)", "mem_ck_n") new_text = new_text.replace("mem_cke(0)", "mem_cke") new_text = new_text.replace("mem_cs_n(0)", "mem_cs_n") new_text = new_text.replace("mem_odt(0)", "mem_odt") new_text = new_text.replace("mem_ras_n(0)", "mem_ras_n") new_text = new_text.replace("mem_we_n(0)", "mem_we_n") f = open('./src/sopc/your_sopc_top_level.vhd', 'w') f.write(new_text) f.close()
