FPGA Intellectual Property
공지
6673 토론
Problem to use LT24 module with qsys and quartus prime 16.1
EGori1
초급자
1,866 조회수
Hi all!
I try to develope simple project with quartus prime 16.1 de-10 lite board and terasic lt24 module (university program), NIOS II and Qsys. I have already downloaded the example from lt24 terasic web page but there are mismatches into the files (in qsys a warning advise to update some IPs). Anyway, in qsys I add a lt24 controller and, according to documentation, a video pll (in order to provide correct clock to daughter board). The lt24 controller has a sink interface linked to a source interface of a video pixel buffer DMA (It has the same clock of LT24 controller IP). Generating HDL and synthesis works fine but the result is onlyh a withe LCD screen. This is the program:
int main()
   printf("avvio il programma\n");
   alt_up_pixel_buffer_dma_dev *buffer;
   buffer = alt_up_pixel_buffer_dma_open_dev("/dev/video_pixel_buffer_dma_0");
alt_up_pixel_buffer_dma_clear_screen(buffer,0);
      alt_up_pixel_buffer_dma_clear_screen(buffer,1);
      alt_up_pixel_buffer_dma_draw_rectangle(buffer, 0, 0, 255, 255, 0x001F, 0);
      alt_up_pixel_buffer_dma_draw_box(buffer,10,10,255,255,0x001F,1);
In the teraisc demo example there are same code and function to initializate the LCD and the LT24 controller but I don't have these code in my auto generated HAL files. Can anyone help me?
I had checked pin assignement in quartus and, of course, the daughter board works fine.
Thanks!
0 포인트
4 응답
KennyTan_Altera
중재자
1,571 조회수
Can you put a link here where you get the terasic demo example?
0 포인트
EGori1
초급자
1,571 조회수
0 포인트
KennyTan_Altera
중재자
1,571 조회수
can you check this out? https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=68&No=1011&PartNo=4#section
Click on the terasic support for the missing files.
0 포인트
KennyTan_Altera
중재자
1,571 조회수
is there any update?
0 포인트
응답
