FPGA Intellectual Property
6671 Discussions
Problem with integer variable and vector range
My code:
Int is an Integer Variable
OutputNumber is a Std_logic_Vector Input
Int <= conv_integer(OutputNumber);
MyVector(37 downto (38-Int)) <= Temp(37 downto (38-Int));
Quartus Compiler Error:
Error (10454): VHDL syntax error: right bound of range must be a constant
PLEASE HELP ME.
The VHDL standard does not allow the right-hand side of downto expresions to contain a variable.
Just use a constant instead of a Int Integer variable.
Thanks for reply, but i don't know the value of Int. I must convert the "OutputNumber" input to know the value of Int.
From your code snippet, it's not fully clear, what you want to achieve. If you want to copy a variable number of bits depending on another condition, you can use a for loop iteration scheme.
for i in 0 to 37 loop if i >= 38 - int then MyVector(i) <= Temp(i); end if; end loop;
"OutputNumber" is a Std_logic_Vector(5 downto 0). It is a vector that store the number of output (eg.: "000000" means no outputs; "01010" means 10 outputs and so on....)
The integer variable "Int" store the equivalent integer value: No outputs: Int:=0; 10 outputs: Int:=10 and so on.....
"Temp" is a 38bit vector, but i need to copy only a range to "MyVector"
Amilcar has already explained, that your code isn't valid VHDL. Try as I suggested or use a similar construct according to VHDL syntax rules.
Ok, so can you help me with an alternative solution?
FvM already gave you an alternative solution.
One other solution would be:
if (OutputNumber == "000000") then
MyVector(37 downto (38-0)) <= Temp(37 downto (38-0)); <- This is wrong because your code was wrong
end
if (OutputNumber == "000001") then
MyVector(37 downto (38-1)) <= Temp(37 downto (38-1));
end
if (OutputNumber == "000010") then
MyVector(37 downto (38-2)) <= Temp(37 downto (38-2));
end
if (OutputNumber == "000011") then
MyVector(37 downto (38-3)) <= Temp(37 downto (38-3));
end
if (OutputNumber == "000100") then
MyVector(37 downto (38-4)) <= Temp(37 downto (38-4));
end
if (OutputNumber == "01010") then
MyVector(37 downto (38-10)) <= Temp(37 downto (38-10));
end
There is no need to use conv_integer. And pleas use numeric_std instead of standard_arith
