FPGA Intellectual Property
6670 Discussions
Problems with simulation of DDR2 SDRAM Controller with UniPHY
I Am using the files for simulation in generated for this IP .
The IP is configured to enable Hard external memory controller, in Aria V, Quartus 12.
The DDR2 SDRAM Controller is set to work with A micron DDR2 : MT47H64M16HW_3IT.
I Have tried to simulate the IP and used the msim_setup.tcl script for that.
The compilation was fine but in simulation , the Micorn DDR2 model does not pass the initialization phase stating :
ERROR: Power Down Failure. Initialization sequence is not complete.
I have also noticed that the AFI_HALF_CLK drives '0' instead of driving half of the ddr2 clock.
The example design works but I can't use it as a functional simulation model in my design cause the interfaces do not match. I will appreciate your guidance with this issue.
Daniel G.
I have also noticed the problems with afi_half_clk when upgrading to Quartus 12.1 When digging into the generated code for the pll the second to last line is "assign afi_half_clk = 1'b0;" I am pretty sure that is the source of the problem there. For the time being i an creating an external Pll to divide down the clock.
-Brian
I provide my workaround for above issue as follows:
S/W: Quartus II 12.0, SP2
Modified file: /[FPGA_PROJECT]/[QSYS_NAME]/synthesis/submodules/[QSYS_NAME]_uniphy_ddr3_pll0.sv
1. find the following codes:
altpll upll_memphy (
.areset (areset),
.inclk (inclk),
.clk (pll_clks),
.locked (pll_locked),
.activeclock (),
.clkbad (),
.clkena ({6{1'b1}}),
.clkloss (),
.clkswitch (1'b0),
.enable0 (),
.enable1 (),
.extclk (),
.extclkena ({PLL_PHASE_COUNTER_WIDTH{1'b1}}),
.fbin (1'b1),
.fbmimicbidir (),
.fbout (),
.fref (),
.icdrclk (),
.pfdena (1'b1),
.pllena (1'b1),
.scanaclr (1'b0),
.scanread (1'b0),
.scanwrite (1'b0),
.configupdate(1'b0),
.scandata(1'b0),
.scandataout(),
.scandone(),
.phasecounterselect({PLL_PHASE_COUNTER_WIDTH{1'b1}}),
.phasedone(),
.phasestep(1'b1),
.phaseupdown(1'b1),
.scanclk(1'b0),
.scanclkena(1'b1),
.sclkout0 (),
.sclkout1 (),
.vcooverrange (),
.vcounderrange ()
defparam upll_memphy.bandwidth_type = "AUTO";
defparam upll_memphy.clk0_divide_by = PLL_AFI_CLK_DIV;
defparam upll_memphy.clk0_duty_cycle = 50;
defparam upll_memphy.clk0_multiply_by = PLL_AFI_CLK_MULT;
defparam upll_memphy.clk0_phase_shift = PLL_AFI_CLK_PHASE_PS;
defparam upll_memphy.clk1_divide_by = PLL_MEM_CLK_DIV;
defparam upll_memphy.clk1_duty_cycle = 50;
defparam upll_memphy.clk1_multiply_by = PLL_MEM_CLK_MULT;
defparam upll_memphy.clk1_phase_shift = PLL_MEM_CLK_PHASE_PS;
defparam upll_memphy.clk2_divide_by = PLL_WRITE_CLK_DIV;
defparam upll_memphy.clk2_duty_cycle = 50;
defparam upll_memphy.clk2_multiply_by = PLL_WRITE_CLK_MULT;
defparam upll_memphy.clk2_phase_shift = PLL_WRITE_CLK_PHASE_PS;
defparam upll_memphy.clk3_divide_by = PLL_ADDR_CMD_CLK_DIV;
defparam upll_memphy.clk3_duty_cycle = 50;
defparam upll_memphy.clk3_multiply_by = PLL_ADDR_CMD_CLK_MULT;
defparam upll_memphy.clk3_phase_shift = PLL_ADDR_CMD_CLK_PHASE_PS;
defparam upll_memphy.clk5_divide_by = PLL_NIOS_CLK_DIV;
defparam upll_memphy.clk5_duty_cycle = 50;
defparam upll_memphy.clk5_multiply_by = PLL_NIOS_CLK_MULT;
defparam upll_memphy.clk5_phase_shift = PLL_NIOS_CLK_PHASE_PS;
defparam upll_memphy.clk6_divide_by = PLL_CONFIG_CLK_DIV;
defparam upll_memphy.clk6_duty_cycle = 50;
defparam upll_memphy.clk6_multiply_by = PLL_CONFIG_CLK_MULT;
defparam upll_memphy.clk6_phase_shift = PLL_CONFIG_CLK_PHASE_PS;
defparam upll_memphy.inclk0_input_frequency = REF_CLK_PERIOD_PS;
defparam upll_memphy.intended_device_family = DEVICE_FAMILY;
defparam upll_memphy.lpm_type = "altpll";
defparam upll_memphy.operation_mode = "NO_COMPENSATION";
defparam upll_memphy.pll_type = "AUTO";
defparam upll_memphy.port_activeclock = "PORT_UNUSED";
defparam upll_memphy.port_areset = "PORT_USED";
defparam upll_memphy.port_clkbad0 = "PORT_UNUSED";
defparam upll_memphy.port_clkbad1 = "PORT_UNUSED";
defparam upll_memphy.port_clkloss = "PORT_UNUSED";
defparam upll_memphy.port_clkswitch = "PORT_UNUSED";
defparam upll_memphy.port_fbin = "PORT_UNUSED";
defparam upll_memphy.port_fbout = "PORT_UNUSED";
defparam upll_memphy.port_inclk0 = "PORT_USED";
defparam upll_memphy.port_inclk1 = "PORT_UNUSED";
defparam upll_memphy.port_locked = "PORT_USED";
defparam upll_memphy.port_pfdena = "PORT_UNUSED";
defparam upll_memphy.port_pllena = "PORT_UNUSED";
defparam upll_memphy.port_configupdate = "PORT_UNUSED";
defparam upll_memphy.port_scandata = "PORT_UNUSED";
defparam upll_memphy.port_scandataout = "PORT_UNUSED";
defparam upll_memphy.port_scandone = "PORT_UNUSED";
defparam upll_memphy.port_phasecounterselect = "PORT_UNUSED";
defparam upll_memphy.port_phasedone = "PORT_UNUSED";
defparam upll_memphy.port_phasestep = "PORT_UNUSED";
defparam upll_memphy.port_phaseupdown = "PORT_UNUSED";
defparam upll_memphy.port_scanclk = "PORT_UNUSED";
defparam upll_memphy.port_scanclkena = "PORT_UNUSED";
defparam upll_memphy.port_scanaclr = "PORT_UNUSED";
defparam upll_memphy.port_scanread = "PORT_UNUSED";
defparam upll_memphy.port_scanwrite = "PORT_UNUSED";
defparam upll_memphy.port_clk0 = "PORT_USED";
defparam upll_memphy.port_clk1 = "PORT_USED";
defparam upll_memphy.port_clk2 = "PORT_USED";
defparam upll_memphy.port_clk3 = "PORT_USED";
defparam upll_memphy.port_clk4 = "PORT_USED";
defparam upll_memphy.port_clk5 = "PORT_USED";
defparam upll_memphy.port_clk6 = "PORT_USED";
defparam upll_memphy.port_clk7 = "port_unused";
defparam upll_memphy.port_clk8 = "PORT_UNUSED";
defparam upll_memphy.port_clk9 = "PORT_UNUSED";
defparam upll_memphy.port_clkena0 = "PORT_UNUSED";
defparam upll_memphy.port_clkena1 = "PORT_UNUSED";
defparam upll_memphy.port_clkena2 = "PORT_UNUSED";
defparam upll_memphy.port_clkena3 = "PORT_UNUSED";
defparam upll_memphy.port_clkena4 = "PORT_UNUSED";
defparam upll_memphy.port_clkena5 = "PORT_UNUSED";
defparam upll_memphy.self_reset_on_loss_lock = "OFF";
defparam upll_memphy.using_fbmimicbidir_port = "OFF";
defparam upll_memphy.width_clock = 10;
2. modify: defparam upll_memphy.port_clk7 = "PORT_UNUSED";
to: defparam upll_memphy.port_clk7 = "port_used"
3. add following codes after instanced altpll upll_memphy():
defparam upll_memphy.clk7_duty_cycle = 50;
defparam upll_memphy.clk7_multiply_by = pll_afi_half_clk_mult;
defparam upll_memphy.clk7_phase_shift = pll_afi_half_clk_phase_ps;
defparam upll_memphy.clk7_divide_by = pll_afi_half_clk_div;
4. find: assign afi_half_clk = 1'b0;
modify it to: assign afi_half_clk = pll_clks[7]
note: Each time you re-generate Qsys system, you should do above workaround again...
Hope this is usefule.:)
