FPGA Intellectual Property
6665 Discussions
Quartus lite and Standard included IPs
MZann1
I am looking into using the following IPs and I couldn't find a list of the free included IPs in Quartus Lite and Standard edition:
1 GbE
10GbE
CAN
FFT
SATA3 or 2
Nathan_R_Intel
Hie,
You will need to select the Device type first before the IP catalog will enable the IP selection. 1GbE and 10GbE is under Interface Protocols/ Ethernet. FFT is available under DSP. SATA is available under Interface Protocols/ Transceivers/Transceiver Native Phy IP as a preset. For CAN are you referring to CAN bus interface. Currently, this is not offered with Quartus.
Please refer to the available user guides for Transceiver and specific interface protocols of the respective devices for more information on the IPs offered by Quartus.
Example:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
Nathan
