FPGA Intellectual Property
6673 Discussions
hello, my testbench work on simulation , but not on board what should I do please thank you
OABBA1
AnandRaj_S_Intel
Hi Oussama,
What is not working on your board? Design or testbench??
When you write a Verilog or VHDL code, you are writing code that will be translated into gates, registers, RAMs, etc. The program that performs this task is known as a Synthesis Tool.
It is the job of the Synthesis Tool to take your Verilog or VHDL code and turn it into something that the FPGA can understand(synthesizable code).
However, there are some parts of Verilog and VHDL that the FPGA simply cannot implement. When you write code like this, it is called non-synthesizable code.
When you write a testbench for simulation, often using non-synthesizable code, which can't be implemented on FPGA.
Anand
OABBA1
Thank you !
I don't know how to add my testbench file on board , it's like i programed my fpga just with the mean code without a testbench... but in modelsim it's working
regards!
AnandRaj_S_Intel
Have you done a pin assignment?
How you are checking it on your board?
Elaborate about your design & Share the code.
Anand
