We have added DMA Engine to the existed PCIe Hard IP Core, changed the design according to DMA (Interface-2X4,128,125MHz, Address width-64(DMA Supports)) and try to do transactions with the external devices.
Here in modified, have configured BAR4(Base address register) for RD/WR Transactions with device.
- I can’t able to configure BAR0 Register for transactions as existed, if we enable Internal descriptor (because BAR0 is internally connected to internal descriptor controller block and it should be 64bit)
- We can configure BAR0 for transactions as existed, if we disable the internal descriptor option( by configuring BAR0 – 32BIT Non prefetchable and BAR4 – 64 BIT Prefetchable)
Need clarification on descriptor controller part, for transactions from PCIe to any external devices.
Without enabling this internal descriptor can we do normal RD/WR operations?
Is it any external descriptor logic is required if we disabled internal descriptor?
May I confirm, the device is Arria10
I also assume, you are using Avalon-MM with DMA
Hi ,
Sorry for the delay in response. Kindly find inline answers
without enabling this internal descriptor can we do normal RD/WR operations?
>> Yes
>> User can use the with their own logic.
Kindly find the reference for the above. Page no: 15
- Tags:
- Hi
