- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
R-tile user-guide: https://www.intel.com/content/www/us/en/docs/programmable/683501/22-2-6-0-0/streaming-tx-interface-tx-st-ready-o.html
> Refer to the Avalon® Interface Specifications for a detailed definition of readyLatency.
The behavior doesn't seem to be called readyLatency.
- What is the value of readyAllowance and readyLatency of this interface?
> The application must not deassert tx_st_valid_i between tx_st_sop_i and tx_st_eop_i on a ready cycle unless there is backpressure from the R-tile PCIe IP indicated by the deassertion of tx_st_ready_o.
What does that mean? deassertion of tx_st_ready_o including the readyAllowance? Example?
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi
readyLatency and readyAllowance have different definition.
Kindly refer to Table 18 of Avalon® Interface Specifications:
https://www.intel.com/content/www/us/en/docs/programmable/683091/22-3/st-interface-properties.html
For a better example and illustration between readyLatency and readyAllowance, you can refer to Figure 27 of Avalon® Interface Specifications:
https://www.intel.com/content/www/us/en/docs/programmable/683091/22-3/data-transfers-using-readylatency-and.html
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Please provide the exact value for both of them.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
It does not follow a fixed latency value between the tx_st_ready_o and tx_st_valid_i signals.
Data can be received any time within the value as specified by the Avalon Interface Specifications.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Could you please read again my question and the R-tile doc?
Once more, the R-tile doc is mixing both and is very unclear.
It says readyLatency but what is shown on the diagram is readyAllowance.
The application must not deassert tx_st_valid_i between tx_st_sop_i and tx_st_eop_i on a ready cycle unless there is backpressure from the R-tile PCIe IP indicated by the deassertion of tx_st_ready_o. For the definition of a ready cycle, refer to the Avalon Interface Specifications.
What does that mean? the real tx_st_ready_o signal or it must not deassert the valid between sop and eop considering the readyAllowance?
The R-tile documentation is too confusing and seems wrong on the terms that are used.
I don't understand the purpose of making it so complicated, why not generating the correct ready signal for good instead?!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I agreed with you that the R-tile user guide has some mistake.
The timing diagram in Figure 31 of R-tile user guide named the 3 cycles between Ready deassertion until Valid deassertion as 'readyLatency', in fact it is defined as 'readyAllowance' in the Avalon Interface Specs.
I can feedback this mistake to internal Documentation team for correction.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
R-tile user guide, section 4.3.1.4. Avalon Streaming TX Interface:
"This interface does not follow a fixed latency between the pX_tx_st_ready_o and pX_tx_stN_dvalid_i signals as specified by the Avalon Interface
Specifications."
It means data can be received any time within the value as specified by the Avalon Interface Specifications.
readLatency: 0-8
readyAllowance: 0-8
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
The maximum latency between the deassertion of tx_st_ready_o and tx_st_valid_i is 16 cycles.
0-8 or 0-16?
It's still unclear about the deassertion of the valid between sop and eop. Can I deassert the valid within the readyAllowance or should I continue until the max (16)?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
There is a note on page 87 of R-tile user guide says:
"Note: This is an additional requirement for the R-tile PCI Express IP core that does not follow the Avalon-ST standard."
So, although Avalon Interface Spec defined 0-8, the R-tile IP accepts readyAllowance up to 16 cycles as it does not follow the Avalon-ST standard.
Q: It's still unclear about the deassertion of the valid between sop and eop. Can I deassert the valid within the readyAllowance or should I continue until the max(16)?
A: Yes, you can deassert the Valid within the readyAllowance without waiting 16 cycles. An example, in Figure 27 of Avalon Interface Spec, in cycle#9 the Valid is deasserted then re-asserted, data D6 and D7 still can be captured (in this case, since readyAllowance=2, it means two more cycle transfers are allowed after ready deasserted).
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
