FPGA Intellectual Property
6673 Discussions
Re-compilation in 10.0 sp1 TSE MAC error
I have a project that is using the TSE MAC and builds fine in Quartus 8.1. When I pull this project up in 10.0 sp1, re-generate in SOPC, and then try to compile in Quartus, I get the following two errors:
error: node instance "altera_tse_mac_inst" instantiated with unknown parameter "enable_extended_stat_reg"
error: node instance "altera_tse_mac_inst" instantiated with unknown parameter "synchronizer_depth"
I have seen one other post on here with exactly this error and the conclusion was stated as having "old files in the project directory". I am still having the problem and don't see any old/conflicting files. Any ideas? :confused:
