FPGA Intellectual Property
6673 Discussions
Reference Design RP to EP?
Zarquin
New Contributor II
Dear Community,
I am looking for a small, well-explained example or tutorial for a very simple data transfer between a PCIe SOC HIP Root Port and an PCIe HIP endpoint.
I worked through this: https://rocketboards.org/foswiki/Projects/PCIeRootPort
and that: https://rocketboards.org/foswiki/Projects/PCIeRootPortWithMSI
But there are files missing and errors occur and the projects are not well enough documented to find the errors without too much effort.
My Dev Kits are:
Best Regards
EBERLAZARE_I_Intel
Can you check from your side if you can access the full design here:
https://releases.rocketboards.org/release/2015.10/pcie-ed/hw/
EBERLAZARE_I_Intel
Do you have any update?
Zarquin
New Contributor II
Dear EBERLAZARE,
I can access the full design files from your link above.
But these seem to be the hardware files from the Rocket PCIe RootPort with MSI example I already have. (?)
The problem with the Rocket examples is that the:
I tried to combine the examples but without success.
Best regards
EBERLAZARE_I_Intel
Unfortunately, you may have to build the Uboot and kernel after compiling the GHRD in Quartus, as demonstrate at the bottom of the page.
EBERLAZARE_I_Intel
Do you have any further questions?
