FPGA Intellectual Property
6669 Discussions
Remote update Flash compatibility: Numonyx M25P40?
JohnHentges
We've designed and are producing / selling a number of Cyclone IV-based designs. We've chosen the Numonyx M25P40 flash chip. Now we want to integrate the “ASMI Parallel IP core” to access FLASH registers and “Remote Update IP core” to perform the in-system programmability feature. Intel IP documents state these IP can be used if the Intel flash device (EPCS4) is used. We'd like to know if the two Intel IP mentioned are anticipated to work with the Numonyx M25P40 flash chip. Upon research, we have found out that the instruction set (to perform FLASH operations) are almost the same for EPCS4 and M25P40, at least for the current needed functionalities of sector and bulk erase, read and write features. Link to the documents: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altasmi_parallel.pdf
NurAiman_M_Intel
Thank you for contacted Intel community.
Intel has not tested FPGA with  Numonyx M25P40, hence we do not assure the if it is compatible or not. Customer may use Numonyx M25P40 if the functionalities are the same but need to be aware that it is not verified and tested by Intel FPGA. Hence we could not provide further support on this.
Apologize for the inconveniences.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
