FPGA Intellectual Property
6669 Discussions
Questions about using Remote Update IP core
RobertLiang
Hello, I'm using Remote Update IP core in my design. The device is cyclone 10LP, and the configuration device is EPCQ64A.
I set the boot address of the application image as 0x400_000 which is half of the address space of the flash device.
But when I was debugging my design, I found that, although the application image was loaded on the FPGA, the value of the boot address of this image I read was wrong.
I wonder if there's any detail I ignored? The parameters I set were as follows.
And the value I read is 0x1_000_000 which is wrong.
Thank you!
NurAiman_M_Intel
Thank you for contacting Intel community.
Apologize for the delay in response as this case was only routed to me today.
  1. I am assuming you have follow this design example, but having problem with the boot address?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf
2.Please let me know if my understanding is correct or not. If you are following the design example, do you check on the design example?
https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/cyclone-10-lp-remote-system-update-design-example/
Aiman
NurAiman_M_Intel
Aiman
NurAiman_M_Intel
Any update fort this request? Else, I will proceed to close this case.
Aiman
