FPGA Intellectual Property
6673 Discussions
Remote upgrade IP-Cyclone V
Gyud0
Hey,
I'm trying to integrate the Remote Upgrade IP in Cyclone V without an Avalon bus and I have two questions:
1) Do I need to integrate the Remote Upgrade IP in the factory design with a state machine that operates it according to page 7 in the user guide ?
2) I'm working with a EPCS128 device so what are the address range of page 0 (the factory image) and page 1 (image 2-application image) ?
Thank you very much!
YuanLi_S_Intel
Please find my response below:
Yes, you need to.
I am assuming you are using Active Serial Configuration Scheme. When you are generating the bitstream for the flash (.jic), you may need to add 2 sof file (factory image and application image), from there, you can select the start address for page 0 and page 1.
Bruce
Gyud0
Thanks, I did it successfully.
Now, I want to add the option "Enable reconfig POF checking" so do I need check the "pof_error" signal in my state machine, before I send the reconfig command from my state machine to the Remote Update IP? I mean before the step 4 in the following order:
Knug
Lucky you are using a configuration device that supports Active Serial (AS) mode.
Our configuration device only supports FPP or PS scheme and we are using MAX V CPLD with PFL.
No luck from our side to use the Remote Update IP within our Cyclone V FPGA for this yet
Kevin
YuanLi_S_Intel
Yes you can do so by reading the "pof_error" indicator before you trigger reconfiguration on steps 4.
Gyud0
I did it =).
Another question, if I give a wrong address to the Remote Update IP, how many addresses the ASMI Parallel IP will search before the "pof_error" indicator will turn on?
YuanLi_S_Intel
The remote update IP will search for address that user entered only. If it is not existed, then "pof_error" indicator will turn on.
Bruce
