FPGA Intellectual Property
6225 Discussions
SCL_LOW, SCL_HIGH, SDA_HOLD register value of Intel FPGA Avalon I2C Master Core
MamaSaru
How can I determine SCL_LOW, SCL_HIGH, SDA_HOLD register value of Intel FPGA Avalon I2C Master Core?
I am planning to initialize the Core from my own designed sequencer.
Thank you.
RichardTanSY_Intel
See attached.
You can refer to this document for more details. Let me know if you need further help.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=173
MamaSaru
No, I mentioned register value not the register location.
I am expecting all these timing is the timing while master driving SCL and SDA by itself.
I easily determine SCL_LOW and SCL_HIGH to define SCL waveform.
But I don't get what SDA_HOLD is.
I expect it is the time to sustain SDA from SCL low or high.
RichardTanSY_Intel
Let's say with a 100MHz input clock and the I2C Master is operating in normal mode of 100KHz.
For SCL_HIGH and SCL_LOW, the register value is (10us/10ns) divide by 2 assuming high and low is same (duty cycle 50:50). For SDA_HOLD, it is (your desired hold period/10ns).
MamaSaru
I have a simple question for SDA_HOLD.
  1. is this timing spec when SDA as output or as input?
  2. is this timing spec for start/stop condition or data transfer?
