FPGA Intellectual Property
6670 Discussions
SDI Decoder IP for MAX10 device
MRudh
I wanted to use SDI II IP. And I am working on MAX10 device family. I know that SDI IP doesn't support MAX10 device. My requirement is SDI decoder. Is there any other IP that I could use for decoding SDI input in the FPGA? Or is there any other way to do it?
CheePin_C_Intel
Hi Monica, As I understand it, you have some inquiries related to SDI II RX. For your information, to decode or receive the SDI input, you would need to use the SDI II IP. You might need to look into other FPGA devices which has the SDI II IP supported. Sorry for the inconvenience.
