FPGA Intellectual Property
6673 Discussions
SDI Megacore refclk_rate
In the v11 SDI userguide it describes the new signal refclk_rate with the following:
refclk_rate : Input : Set input 0 for a 148.35-MHz RX serial reference clock and input 1
for 148.35-MHz RX serial reference clock.
Ok, so what do I set it to for 148.5MHZ ref clock?:confused:
Cheers,
Simon
i filed an SR on this:
Below statement is the corrected one.
Set input 0 for a 148.35-MHz RX serial reference clock and input 1 for 148.5-MHz RX serial reference clock.
Thanks! That seems to work.
