FPGA Intellectual Property
6670 Discussions
Sample rate problem with Output Block of DSP Builder
Hello
I have a sample rate problem with the Input or Output Block (sInOut S-function block) when I try to simulate my model in Matlab.
After this kind of block, it is always convert the sample rate of my signal to 1 second.
Here an example of my problem :
Here a part of my model, a put two scope : scope2 with an audio signal and scope1 with the signal after the Output Block.
http://www.alteraforum.com/forum/attachment.php?attachmentid=9844&stc=1
An image of the Scope 2 with the Audio signal :
http://www.alteraforum.com/forum/attachment.php?attachmentid=9845&stc=1
An image of the Scope 1 whith the signal after the Output Block.
http://www.alteraforum.com/forum/attachment.php?attachmentid=9846&stc=1
As you can see, the sample rate was shrink to 1 second so I miss all the details of my signal.
How can I fix it ?
Thanks a lot for your help, I've working for hours on this problem.
I send you my entire project attached to this post.
Yann
