FPGA Intellectual Property
6670 Discussions
Video Processing Problem
I am using Cyclone III Development Board and I want to take an input from computer via Bitec DVI receiver and directly pass it to monitor via Bitec DVI transmitter.
Here is the code, I used and I could not achieve what I want and have no idea why does it not work ?
Appriciate your answers
entity top is
port(
clk : in std_logic;
BITEC_DVI_IO_IN : in std_logic_vector(23 downto 0);
BITEC_DVI_IO_IN_DE : in std_logic;
BITEC_DVI_IO_IN_HSYNC : in std_logic;
BITEC_DVI_IO_IN_ODCK : in std_logic;
BITEC_DVI_IO_IN_VSYNC : in std_logic;
BITEC_DVI_IO_OUT_HSYNC : out std_logic;
BITEC_DVI_IO_OUT_DE : out std_logic;
BITEC_DVI_IO_OUT : out std_logic_Vector(23 downto 0);
BITEC_DVI_IO_OUT_VSYNC : out std_logic;
BITEC_DVI_IO_OUT_DVI_ISEL : out std_logic;
BITEC_DVI_IO_OUT_DVI_PD : out std_logic;
BITEC_DVI_IO_OUT_DVI_DKEN : out std_logic;
BITEC_DVI_IO_OUT_DVI_CTL1 : out std_logic;
BITEC_DVI_IO_OUT_DVI_CTL2 : 0ut std_logic;
BITEC_DVI_IO_OUT_DVI_CTL3 : out std_logic;
BITEC_DVI_IO_OUT_IDCKp : out std_logic;
BITEC_DVI_IO_OUT_IDCKn : out std_logic
end top;
architecture behavioral of top is
component vidout2
port (
is_clk : in std_logic := '0'; -- is_clk_rst.clk
rst : in std_logic := '0'; -- is_clk_rst_reset.reset
is_data : in std_logic_vector(23 downto 0) := (others => '0'); -- din.data
is_valid : in std_logic := '0'; -- .valid
is_ready : out std_logic; -- .ready
is_sop : in std_logic := '0'; -- .startofpacket
is_eop : in std_logic := '0'; -- .endofpacket
vid_clk : in std_logic := '0'; -- clocked_video.export
vid_data : out std_logic_vector(23 downto 0); -- .export
underflow : out std_logic; -- .export
vid_datavalid : out std_logic; -- .export
vid_v_sync : out std_logic; -- .export
vid_h_sync : out std_logic; -- .export
vid_f : out std_logic; -- .export
vid_h : out std_logic; -- .export
vid_v : out std_logic -- .export
end component;
component vidin
port (
is_data : out std_logic_vector(23 downto 0); -- dout.data
is_valid : out std_logic; -- .valid
is_ready : in std_logic := '0'; -- .ready
is_sop : out std_logic; -- .startofpacket
is_eop : out std_logic; -- .endofpacket
vid_data : in std_logic_vector(23 downto 0) := (others => '0'); -- .export
overflow : out std_logic; -- .export
vid_datavalid : in std_logic := '0'; -- .export
vid_locked : in std_logic := '0'; -- .export
vid_v_sync : in std_logic := '0'; -- .export
vid_h_sync : in std_logic := '0'; -- .export
vid_f : in std_logic := '0' -- .export
end component;
signal locked :std_logic:='0';
signal c0,ready,valid,eop,sop,underflow,overflow,f,h,v: std_logic:='0';
signal data : std_logic_vector(23 downto 0):=(others=>'0');
begin
l2: vidin port map(clk,'0',data,valid,ready,sop,eop,BITEc_DVI_IO_IN_ODCK,BItEC_DVI_IO_IN,overflow,BITEC_DVI_IO_IN_DE,'1',BITEC_DVI_IO_IN_VSYNC,BITEC_DVI_IO_IN_HSYNC,f);
l3: vidout2 port map(clk,'0',data,valid,ready,sop,eop,BITEc_DVI_IO_IN_ODCK,BITEC_DVI_IO_OUT,underflow,BITEC_DVI_IO_OUT_DE,BITEC_DVI_IO_OUT_VSYNC,BITEC_DVI_IO_OUT_HSYNC,f,h,v);
BITEC_DVI_IO_OUT_IDCKp<=BITEC_DVI_IO_IN_ODCK;
BITEC_DVI_IO_OUT_DVI_ISEL<='1';
BITEC_DVI_IO_OUT_DVI_PD <='0';
BITEC_DVI_IO_OUT_DVI_DKEN <='0';
BITEC_DVI_IO_OUT_DVI_CTL1 <='0';
BITEC_DVI_IO_OUT_DVI_CTL2 <='0';
BITEC_DVI_IO_OUT_DVI_CTL3 <='0';
BITEC_DVI_IO_OUT_IDCKn <='0';
end behavioral;
I did not look in deep to your code, but for a simple loopback you would just need wires from the input to the output.
Could you provide a bigger picture of your system as I see some Avalon-ST Signals in your components...
