FPGA Intellectual Property
6673 Discussions
Signal problem, MM-SLAVE
My goal is to have a system with a Nios ii processor as a master. The processor should send data to 20 slave units, custom logic, PWM-generators. The data to be sent is just the top value for the PWM-signal. I'm completely new to this, so I've probably done tons of mistakes. Anyhow here's the VHDL code:
entity PWMtest is
Port (
EXTCLK_I : in STD_LOGIC; -- From the 50MHz clock generator
PWM_O1, PWM_O2 : out std_logic;
DATA_ARRIVED : in std_logic;
DATA_IN : in STD_LOGIC_VECTOR(7 downto 0)
end PWMtest;
architecture Behavioral of PWMtest is
signal clk_50M : std_logic; -- we use this signal for clk
signal counter : std_logic_vector(7 downto 0) := (others => '0');
signal pwm : std_logic;
begin
clk_50M <= EXTCLK_I;
PWM_O1 <= pwm;
PWM_O2 <= NOT pwm;
process(clk_50M)
begin --process
if (clk_50M'event and clk_50M='1') then
if counter < DATA_IN then
pwm <= '1'; -- the pwm output is high
else -- the rest of the cycle
pwm <= '0'; -- the pwm output is low
end if;
counter <= counter+1; -- The counter just runs and runs and runs
end if;
end process;
end Behavioral;
I want to add that VHDL-file in to a component but I have no clue how to get this work. I've tried to read: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf but it's probably not meant to be read by a newbie like me, because I didnt understand much at all.
Anyhow below have I taken a screenshot of how it looks in my SOPC-builder. What signals should I have if I wanna read the DATA and then perform a PWM signal with data from the nios processor? Would be happy if someone had a tutorial or anything easier than the avalon specifications.
http://img695.imageshack.us/i/sopco.jpg/ <---- Screenshot of how where I am right now in my attempt to get this to work.
Mr_embedded
