FPGA Intellectual Property
6385 Discussions
Simulating PCIE_DDR4: what are the complete setup contents.
treble99
I am trying to simulate the reference PCIE_DDR for the Terasic De5a-NET DDR4 board. I was referring to Intel Documentation https://www.intel.com/content/www/us/en/docs/programmable/683162/23-1-2-7-0/simulating-external-memory-interface.html
My questions are:
1. Is following section 2.6 sufficient in running simulation? [Attached Screenshot]
The msim_setup.tcl script is just sourcing device and design libraries etc.  At what parts is it driving the design?
I can run ld_debug and I do see Objects in window. But I want to meaningfully verify DDR read/writes in simulation.
2. If a separate testbench script is needed which in turn sources msim_setup.tcl. Where can I find an example of such a testbench?
The `Generate` -> `Generate Testbench System` option in my understanding stops at providing msim_setup.tcl script.
Further this design used PCIe Hard IP. BFM are one such way of simulation.
3. Is there a BFM testbench script available for reference?
I was not able to find it. And it is confusing to build one owing to complex design(atleast for me.)
An answer to above questions is greatly appreciated.
I can also provide additional information if needed.
Thank you,
Manish
wchiah
>> Are you trying to simulate PCIe design or Emif design ?
>> if it is memery interface issue, you may refer to our official youtube channel which there got step by step guide to run the simulation
>> https://www.youtube.com/watch?v=iCr-0eOwo9o&ab_channel=IntelFPGA
>> Please refer to answer in question 1, the video shall explain how you generate the testbench for simulation
Can I know which tile that you are referring for the PCIe HIP ? P-tile ? R-tile or others...
Wincent_Intel
wchiah
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
treble99
Hello Wincent,
Thank you for the link I am reviewing it and I will get back to you by the end of this week. Primarily I am not still not sure where the stimulus is sent from, driving the signals.
In the PCIe_DDR example I want to simulate reading/writing to DDR memory. I want to verify meaningfully some data being read and written to DDR. Please suggest the setup for it.
I have not worked on PCIe designs before, can you please point out where I can find this information for you.
Thank you,
Manish
wchiah
>> the video shall be clear, please refer and try to run it.
>> for PCIe_DDR you may refer to https://www.intel.com/content/www/us/en/docs/programmable/683390/quartus-prime-pro-v17-0-arria-10/pci-express-dma-reference-design-using.html
Is okay, you are using Arria 10, it is PCIE Hard IP.
Wei Chuan
wchiah
I wish to follow up with you about this IPS case.
​​​​​​​Else I would like to have your permission to close this IPS ticket
Wei Chuan
wchiah
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
