FPGA Intellectual Property
6382 Discussions
Stratix 10 - Transceiver reconfiguration settings for 10G and 20G link rate
HBhat2
New Contributor II
I am using Stratix 10 SoC Dev kit for high speed communication PoC. The communication link must negotiate to either 10G or 20Gbps link rate. If I see the Native PHY for Stratix 10, I need to use GX XCVR type for 10Gbps and GXT XCVR type for 20Gbps. My question is whether I can achieve the 10Gbps and 20gbps functionality in a single binary with the help of Dynamic reconfiguration block? If Yes, please guide me the procedure to configure the Dynamic reconfiguration profiles by changing XCVR types to GX and GXT.
With Regards,
HPB
CheePin_C_Intel
Hi HPB, You are right, the note seems confusing. For your information, I have consulted Factory and get to know that this feature is already supported with the current latest Quartus release ie 18.1Pro. This seems to be a typo in the user guide and I have filed a case to remove the confusing note on future release support. Sorry for the inconvenience. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
CheePin_C_Intel
Hi HPB, As I understand it, you have some inquiries related to reconfiguring from GX channel to GXT channels. By merely based on the observation from performing some checks by playing around with the configuration in Native PHY, it seems like it is something workable as there is no specific error prompted. The following is what I did for your reference: 1. Open up a S10 H-Tile Native PHY 2. Select Low latency GT preset, change to 1 CH and then store into configuration profile 0 after enabling the dynamic reconfiguration and multi configuration profiles. 3. Change the configuration to GX and then reduce the data rate to 10312.5Mbps, then store into configuration profile 1. There seems to be no error prompted by the Native PHY. As next step, it is recommended for you to create a test bench and perform a Modelsim simulation to see if the dynamic reconfiguration will work as expected to change between GXT and GX. You can enable the embedded reconfiguration streamer to ease the reconfiguration between profiles. Please let me know if there is any concern. Thank you. Best regards, Chee Pi
HBhat2
New Contributor II
Hi Chee Pi,
Thank you for your explanation and I am considering simulation as well.
Further, I was going through Stratix 10 XCVR user guide and found "6.9.3. Reconfiguring Between GX and GXT Channels". Going through the same chapter now.
With Regards,
HPB
CheePin_C_Intel
Thanks for your update.
HBhat2
New Contributor II
I was reading "6.9.3. Reconfiguring Between GX and GXT Channels" and found below statement.
"Dynamic reconfiguration between GX and GXT datarates will be supported in a future Intel Quartus Prime Pro Edition release."
Although, now I am able to configure 2 dynamic reconfiguration profiles with 10gbps(GX data rate) and 20Gbps (GXT data rate) in the Platform designer /qsys and able to generate HDL, above statement is creating some doubts.
With Regards,
HPB
CheePin_C_Intel
HBhat2
New Contributor II
Thank you @cheepinc_Intel​  for getting the clarification from factory. I am using Quartus 18.1 pro.
With Regards,
HPB
