FPGA Intellectual Property
6673 Discussions
Stuck while building the VIP Example Design
We are trying to get the vip_example_design_3c120_v81_revc up and running on an Cyclone III EP3C120F780 Dev Kit. It is an427.pdf.
I am getting stuck in the Analysis & Elaboration with the following errors...
--- Quote Start ---
Error: Node instance "my_alt_vip_clip" instantiates undefined entity "alt_vip_clip_GNC4EQ5CK4"
Error: Node instance "my_alt_vip_clip_1" instantiates undefined entity "alt_vip_clip_GNPBQZW3LV"
Error: Node instance "my_alt_vip_cpr" instantiates undefined entity "alt_vip_cpr_GN2NSRR73L"
Error: Node instance "my_alt_vip_crs" instantiates undefined entity "alt_vip_crs_GNWKGGJH2A"
Error: Node instance "my_alt_vip_csc" instantiates undefined entity "alt_vip_csc_GNFW7UOZX6"
Error: Node instance "my_alt_vip_dil" instantiates undefined entity "alt_vip_dil_GNN35ONPP5"
Error: Node instance "my_alt_vip_mix" instantiates undefined entity "alt_vip_mix_GNVFXMO3FD"
Error: Node instance "my_alt_vip_scl" instantiates undefined entity "alt_vip_scl_GN4UL6JZTM"
Error: Node instance "my_alt_vip_tpg" instantiates undefined entity "alt_vip_tpg_GNM5FCQ7QA"
Error: Node instance "my_alt_vip_vfb" instantiates undefined entity "alt_vip_vfb_GNV62V62MH"
Info: Generated suppressed messages file C:/Source/CycloneIII/vip_example_design_3c120_v81_revC/vip_top.map.smsg
Error: Quartus II Analysis & Elaboration was unsuccessful. 10 errors, 118 warnings
--- Quote End ---
I am new to FPGA development, so am currently somewhat overwhelmed with the many IDE options. We have added the VIP libraries to the project, something the document forgets to mention, but there is a good chance I could be missing some other critical library path.
William Guynes
It appears this error occurs if the user executing the Quartus II IDE does not have Administrator permissions.
Is it Altera's position that all FPGA developers have Administrator access? (to the local machine, not the domain)
If not, what sub-permissions must the developer account be granted in order to successfully compile?
Try deleting both the DB and incremental_db directories and rebuild the project.
Mike
I had tried deleting db/* and incremental_db/* very early in the troubleshooting, but it wasn't having any effect.
For some reason Quartus is requiring Administrator permissions on the compile machine. An Altera S.R. is open to see exactly what permissions it requires. Does it really need everything?
I doubt this is a _directory_ permissions issue though. My regular account had Full permissions to the C:\Source directories (where my projects reside), but only had Read access to the C:\Altera branch. We opened up the C:\Altera to Full privileges in order to test that theory, but it gave the same error.
This appears to have something to do with executable permissions. I'm not a Windows administrative expert, but IT has established that the domain restrictions are not causing it. It is the local machine executable permissions which, as far as we can tell, requires the user to be a member of the "Administrator" group. If someone has a [Windows] "non-Administrator" account compiling, please speak up. I would be interested in hearing about it.
I am also having the exact same problem as above.
I should note that I am using windows vista.
The compiler seems unable to locate the video and image processing
IP block primatives.
I have been able to get the design to compile without problems on two other machines in my office, both of which are running windows XP.
I think I just figured out a workaround based on the comments about needing to have admin rights.
My login to my vista machine has admin permissions. It just does not invoke them unless you explicitly tell it to do so.
Quartus was unable to locate the VIP primitives because vista was keeping them hidden.
What I did was right click the short cut to quartus 8.1 on my desktop and hit run as administrator.
Now I no longer receive the undefined entity errors about the VIP primitives.
this is an interesting problem, wguynes: are you also running Windows Vista?
I am running Windows XP.
Hi
I do run Vista and see the same problem on 2 PC's
No change when I do start the Quartus8.1 shortcut "run as administrator"
Any new info on this problem?
Wiljan
I submitted a service request about the issue. Once I discovered it worked as Administrator I asked this question in an update...
--- Quote Start ---
Compile finishes successfully *if* the Quartus II software is run as a Administrator (on the local machine, not the domain). Not all developers are given administrator access.
Is it Altera's position that all FPGA developers have full Administrator access?
If not, what sub-permissions must the user running the Quartus II IDE/Compiler have in order to compile successfully?
--- Quote End ---
...to which Altera responded...
--- Quote Start ---
Thanks for your update. It is good news that you have solved this issue .
I have communicated this kind of issue with SW group. This is from the software environment requirement.
The IP Core and megacore need java/cusp support, so we recommend customer run the QII in root/ administrator.
--- Quote End ---
I am currently launching Quartus as Administrator and the problem is a non-issue. This is not an ideal development environment in my view, but I have to keep moving forward.
William Guynes
Hi wguynes
I just tried again as administrator and I still get those errors
Info: Generated suppressed messages file C:/altera/81/vip_example_design_3c120_v81_revC/vip_top.map.smsg
Error: Quartus II Analysis & Synthesis was unsuccessful. 10 errors, 106 warnings
Error: Peak virtual memory: 332 megabytes
Error: Processing ended: Tue Feb 17 14:08:48 2009
Error: Elapsed time: 00:01:00
Error: Total CPU time (on all processors): 00:00:43
Error: Quartus II Full Compilation was unsuccessful. 12 errors, 106 warnings
I will try on a XP machine tonight and see if this make any difference
Wiljan
HI
Now I tried on my old P4 xp PC and it worked in first go :-) (2h45m)
On my Vista PC I do log in as administrator and I do run Quartus81 as administrator.... and it fails
I was wondering if the Quartus instaliation should has been executed as administator when it was installed?
I would realy like to have it to work on my Vista PC since it's a quad core
Wiljan
My installation was installed as Administrator to give all users access. It also requires building as Administrator.
So, our theory now is that if I had installed it as... say... "User" then it would successfully build as "User" but maybe not as "User2"?
William Guynes
Hmmmm
I'm the only user... and this user are administator... a bit wierd
But in Vista it might still make a change when installing to right click and say run as administrator...even I'm allready administrator... I'm tired of Vista a lot of waisted time
You did mention a folder being hidden, perhaps I can change the permision for this folder?
Wiljan
Hi
I am new to FPGA development,Where can I download the vip_example_design_3c120_v81_revc .zip
email:lusuyi2009@163.com
Thank you!
lusuyi2010
vip_example_design_3c120_v91_revB can be found here (https://www.altera.com/support/software/download/refdesigns/broadcast/dnl-post-process.jsp?swcode=www-ref-dev-video).
The filename is video.zip, but the contents are the 9.1 version of what you asked for. 8.1 is out of date and I am not sure where to find a legacy copy.
Hi wguynes
Thank you for your help!
lusuyi2010
