FPGA Intellectual Property
6672 Discussions
Switch version have some compile errors
FZhao12
Partner
Error(18694): The reference clock on PLL "u_gmax2500|u_lvds_dpa_x16|lvds_0|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll", which feeds an Altera LVDS SERDES IP instance, is not driven by a dedicated reference clock pin from the same bank. Use a dedicated reference clock pin to guarantee meeting the LVDS SERDES IP max data rate specification.
之前17.2编译没问题的,现在换成了19.4报这个错误
JonWay_C_Intel
Hi @FZhao12​  You will need to assign it to a dedicated clock input pin on the same bank. I remember that newer version will block you from using IO pin as clock input to avoid your LVDS SERDES not performing up to specification.
Hope this answers your questions.
FZhao12
Partner
thanks ​There are no other questions for the moment
