FPGA Intellectual Property
6673 Discussions
Sync signal of VIP Clocked Video Input
Hey guys,
Just one quick question about the sync signals of Clocked Video Input megacore:
The manual said vid_h_sync should be set to 1 when video is in horizontal synchronization period. But what is the horizontal synchronization period here? Is it Front porch, Back porch, Sync pulse or Active Sample? Thanks very much!
vid_h_sync is only referring to the horizontal synchronization period and not the blanking period.
If you read the section on Separate Synchronization Format it hints that vid_h_sync is strictly the horizontal synchronization period, and does not include the blanking periods. This can be seen further through the timing diagram, where the h_sync pulse is asserted between the two vid_datavalid sections. The vid_datavalid indicating active picture period.
The documentation could be more explicit on this.
Thanks for your reply. I have just gone over the manual. Just to double confirm:
the horizontal data flow is: H front porch -> H Sync -> H back porch -> pixel data, and then repeat itself.
h_sync is asserted during "H Sync" only; and vid_datavalid is asserted during "pixel data" only. Is that correct?
Thanks very much!
--- Quote Start ---
That is correct. The h_sync signal is not asserted during the front porch or back porch periods of the horizontal blanking period, and the vid_datavalid is asserted during the active picture time.
Did you get this running? I am running into a issue trying to create a test pattern into the Clocked Video Input. The clocked video input is set to 800x600. What is the front porch and back porch settings and sync timing you used?
I was using 640x480, and I got it working.
The timing info I used comes from the link below:
http://tinyvga.com/vga-timing
The key is that either "Sync pulse" or "Sync pulse + Front porch + Back porch" should be set as blank period. Sorry I forgot which setting I was using. But you should be able to figure it out after trying both. :o
