FPGA Intellectual Property
6670 Discussions
System console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Vamsi_21
Nouveau contributeur I
16 391 Visites
I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document.
https://www.intel.com/content/www/us/en/docs/programmable/683063/19-1-19-1/10m-100m-1g-10g-ethernet-design-example.html
While testing it on the hardware, I am getting the below error from system console.
“error: master_write_32: This transaction did not complete in 60 seconds. System console is giving up.
While executing
“master_write_32 sport_id $address $wdata”
(procedure “reg_write” line 7)
invoked from within
“reg_write $PHY_IP_BASE_ADDR $seq_control 0X111”
(procedure “SETPHY_SPEED_1G” line
invoked from within
“CONFIG_IPORT $speed_test”
(procedure “TEST_PHYSERIAL_LOOPBACK” line 10)
invoked from within
TEST_PHYSERIAL_LOOPBACK 0 1G 1000”
I have changed the USB blaster frequency to 16MHz,6MHz but still I am getting the issue.
Details:
Quartus used : Quartus prime 22.2
Board :Intel arria 10 GX development board
Device : 10AX115S2F45I1SG.
Below are the clock pin assignments
Name pin assigned
mm_clk 125Mhz BD24 clk_125
ref_clk_1g 125MHz N37 REFCLK_SMA (modified using clk controller).
ref_clk_10g 644.53125Mhz AA37 REFCLK_SFP
Étiquettes (1)
0 Compliments
45 Réponses
ZiYing_Intel
Employé
8 052 Visites
Hi Vamsi_21,
May I know that you are using your own board or devkit during the testing?
zying
0 Compliments
Vamsi_21
8 040 Visites
Iam using intel Arria10 GX development board for the testing.
Device:10AX115S2F45I1SG
0 Compliments
ZiYing_Intel
Employé
8 006 Visites
Hi Vamsi_21,
I can run the design example successfully.
zying
0 Compliments
ZiYing_Intel
Employé
8 006 Visites
Hi Vamsi_21,
Can you check how many jtag service ports and what index number of desired port by "get_service_paths master" command in the system console?
This index number is used in the "hwtest/basic/basic.tcl".
zying
0 Compliments
Vamsi_21
7 957 Visites
I have run the "get_service_paths master" command in the system console.
Below i am attaching the image of the system console window.
Previous screenshots which you have attached, i am not able to view or download them.
0 Compliments
ZiYing_Intel
Employé
7 942 Visites
Hi Vamsi_21,
zying
0 Compliments
Vamsi_21
7 889 Visites
The same index number is there in the hwtesting/basic/basic.tcl.
Below iam attaching the screenshot.
0 Compliments
ZiYing_Intel
Employé
7 857 Visites
Hi Vamsi,
I already sent the example design to your email and glad to hear that you can run successfully. For the issue on 100G, can you share your .qar file here?
zying
0 Compliments
Vamsi_21
7 820 Visites
Can you the share the  .tcl scripts for 10G Etherent which you have used for testing on the board because for any test i run iam getting the same output irrespective of the channel, data-rate, burstsize .
0 Compliments
ZiYing_Intel
Employé
7 776 Visites
Hi Vamsi,
Here's the .tcl script.
zying
0 Compliments
Vamsi_21
7 674 Visites
I have tested on the board with the .tcl scripts you have shared and have found the irrespective of any changes like burst-size, data rate  and different tests like PHYSERIAL_LOOPBACK and SMA_LOOPBACK
It is showing same "throughput calculated" for every speed.
Below I am attaching the screenshots for:
PHYSERIAL_LOOPBACK for channel 0 , 1G speed, 1000 burst size,
PHYSERIAL_LOOPBACK for channel 0, 10G speed, 1000 burst size,
SMA_LOOPBAACK for channel 0, 10G speed, 1000 burst size.
device details:
NAME: ARRIA 10 GX development board
DEVICE: 10AX115S2F45I1SG
0 Compliments
ZiYing_Intel
Employé
7 729 Visites
Hi Vamsi,
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
0 Compliments
Vamsi_21
7 724 Visites
  • Hello,
    Iam testing with the tcl scripts which you have shared and need some time analysing them because previously when i tested on the board i got the same results for every test irrespective of channel, data- rate , burst size
0 Compliments
Vamsi_21
7 529 Visites
As I have mentioned above , I have checked with the .tcl scripts you have shared and found the output was same irrespective of any test_speed , can you look into this issue?
@ZiYing_Intel
0 Compliments
ZiYing_Intel
Employé
7 511 Visites
Hi Vamsi,
Give me some time to work on this issue.
zying
0 Compliments
Vamsi_21
6 988 Visites
0 Compliments
Vamsi_21
6 391 Visites
0 Compliments
ZiYing_Intel
Employé
6 384 Visites
Hi Vamsi_21,
Currently I don't have any update. I now transition this thread to community support. The community users will continue to help you on this thread.
zying
0 Compliments
Vamsi_21
6 375 Visites
Is there any hardware_test_design avaialble for Low latency 100g Ethernet intel FPGA ip example design.
I have generated an example design but it isn't working on the hardware ,  I am getting the below error:
"TTK failed reading from PHY slave_10000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset."
This error is same as the one i got for 10g ethernet design , so can you help me on this issue for the 100g design as well.
0 Compliments
ZiYing_Intel
Employé
6 226 Visites
Hi Vamsi,
I sent the example design for 100g to your email dy. Hope it was helpful to you.
zying
0 Compliments
Vamsi_21
6 214 Visites
Can you share the 100g design for 22.2 Quartus version.
While trying to open the design you sent it is showing " project archive restoration failed. project may be archived from a different quartus version."
0 Compliments
Répondre
