FPGA Intellectual Property
公告
6673 讨论
System console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Vamsi_21
新分销商 I
16,879 次查看
I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document.
https://www.intel.com/content/www/us/en/docs/programmable/683063/19-1-19-1/10m-100m-1g-10g-ethernet-design-example.html
While testing it on the hardware, I am getting the below error from system console.
“error: master_write_32: This transaction did not complete in 60 seconds. System console is giving up.
While executing
“master_write_32 sport_id $address $wdata”
(procedure “reg_write” line 7)
invoked from within
“reg_write $PHY_IP_BASE_ADDR $seq_control 0X111”
(procedure “SETPHY_SPEED_1G” line
invoked from within
“CONFIG_IPORT $speed_test”
(procedure “TEST_PHYSERIAL_LOOPBACK” line 10)
invoked from within
TEST_PHYSERIAL_LOOPBACK 0 1G 1000”
I have changed the USB blaster frequency to 16MHz,6MHz but still I am getting the issue.
Details:
Quartus used : Quartus prime 22.2
Board :Intel arria 10 GX development board
Device : 10AX115S2F45I1SG.
Below are the clock pin assignments
Name pin assigned
mm_clk 125Mhz BD24 clk_125
ref_clk_1g 125MHz N37 REFCLK_SMA (modified using clk controller).
ref_clk_10g 644.53125Mhz AA37 REFCLK_SFP
标签 (1)
0 项奖励
45 回复数
ZiYing_Intel
员工
1,464 次查看
Hi Vamsi,
I sent example design quartus version 22.2 to your email.
Best regatrs,
zying
0 项奖励
ZiYing_Intel
员工
1,443 次查看
Hi Vamsi,
For the issue about the output is always the same irrespective of 10g/1g speed, burst size and different tests like PHYSERIAL_LOOPBACK and SMA LOOPBACK, I also got the same result as you mentioned after few tries.
zying
0 项奖励
Vamsi_21
新分销商 I
1,428 次查看
I had also gone through the .tcl scripts for the 10g design but was not able to find out the reason for the same output irrespective of different tets.
For the 100g design you have sent , I am still getting the TTK failed reading phy slave _10000 cannot enable ttk functionality .....
0 项奖励
ZiYing_Intel
员工
1,353 次查看
Hi Vamsi,
Since the A10 device is too old, it was actually out of our plan and the bug was planned to be fixed in Quartus version 24.2. I now transition this thread to community support. The community users will continue to help you on this thread.
Zi Ying
0 项奖励
回复
