FPGA Intellectual Property
6673 Discussions
The output signal din_ready from the model cpr
The model is from the image and video processing IP. When I run the simulation, it display as follows for din_ready.
https://alteraforum.com/forum/attachment.php?attachmentid=14110&stc=1
I don't known the reason for the din_ready gi low, is ut whether the input sop and valid problem, thanks
Hi Jiangsuren,
The din_ready signal is a backpressure signal, it is normal to goes low whenever the IP is unable to receive more data. But it is abnormal if this signal keep de-asserted. If this is the case, you may also check whether the dout_signal also de-asserted because the problem may cause by downstream component.
Terence
(This message was posted on behalf of Intel Corporation)
