FPGA Intellectual Property
6673 Discussions
There is problem in using Avalon MM Master read
I try to use avalon MM Master read.
But there is one problem.
"master_read" output can not be one.
I attach two figure.
One is modelsim wave test and the other is avalon MM Master setting.
Thank you!
http://www.alteraforum.com/forum/attachment.php?attachmentid=12393&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=12394&stc=1
and do you also have the implementation? Seems that your signals gets assigned in a wrong way, which leads to an undefined state...
