FPGA Intellectual Property
6669 Discussions
Transceiver toolkit doesn't recognize a link
What should be done in the transceiver-oriented design in order to be exploited with "Transceiver Toolkit".
I've tried 2 examples downloaded from Altera site:
  • 10Gbps low latency
  • 10GBase-R
In 1st case I could use Transceiver Toolkit, in 2nd - NOT.
The 1st one was done with Qsys, 2nd - without Qsys (IP was generated by wizard).
The question: Is creaing of a design with Qsys necessary condition for using Transceiver Toolkit.
Pavel.
I am having the same problem. My first design was done with qsys and it was working with transceiver toolkit without any problems, now I am working with a design where the different components have been created with megawizard and I cannot use the transceiver toolkit, because it doesn't recognize the link.
Did you find any solution?
