FPGA Intellectual Property
6669 Discussions
Tri speed Ethernet Interface Testbench for MAX 10 Device
Dear All, In Ethernet option of Interfce protocol in Quartus prime lite edition software there is a testbench for Ethernet protocl. If i want to send some data from FPGA to PC via Ethernet then should i write a verilog code or i can use this default testbench for Ethernet protocol. Sorry if you find this question dumb. But i am quite freaking out about the verilog code of Ethernet interface. Thanks in advance
If you want to run simulation, you can use the default testbench.
You can also consider refer to example below:
MAX 10 Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example
https://cloud.altera.com/devstore/platform/15.1.0/max-10-single-port-triple-speed-ethernet-and-on-board-phy-chip-design-example/
(This message was posted on behalf of Intel Corporation)
