FPGA Intellectual Property
6659 Discussions
Triple-Speed Ethernet enable jumbo frame
efiovadia
I'm using QSYS 18.1 with Triple-Speed Ethernet IP set for: 1000BASE-X/SGMII PCS Only with Stratix IV.
I want to use it for Jumbo frames, and I read the IP User Guide section 10.5 which shows the Jumbo frames' definitions as shown in the figure below:
I tried to change the definitions according to the above, but it seems that the QSYS / generated BSP not using these files. they don't compile them. I assume because of the PCS only option.
Is there a way to set the Jumbo frame for my settings, or what I'm I doing wrong?
Thank you,
efiovadia
Sorry for my late response,
We don't have error during compilation, but we understood that the limitation comes from the switch we are connected  to.
Thank you very much,
Efi
paveetirrasrie_Intel
Good day to you
May I know what do you mean by it doesn't compile? Any error during compilation?
Pavee
Good day to you.
Any update from my previous query?
Pavee
We do not receive any response from you to the previous question that I have raised.
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
efiovadia
Efi
