FPGA Intellectual Property
6664 Discussions
User MSI generation with DMA enabled
andrecap
I'm having trouble in generating an MSI in my Endpoint FPGA.
I am using Cyclone 10 GX with "Hard IP for PCI Express"(Avalon-MM) and DMA support.
The MSI is already working when a DMA transaction completes, but I want to send another one defined by the application logic.
I tried to use the Avalon-MM to PCI Express Mailbox Registers (0x3A00) and the Avalon-MM to PCI Express Interrupt Enable Register (0x0050) from CRA, but I don't receive any MSI at the RootPort site.
It also seems that the IER cannot be accessed in WRITE mode.
Some notes:
- MSI is enabed in configuration space.
lspci interesting lines:
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Capabilities: [50] MSI: Enable+ Count=1/4 Maskable- 64bit+
- CRA is enabled. There are no IRQ signals coming out of the CRA interface (but there should be as specified in 8.2 of the ug_a10_pcie_avmm).
Do you have any suggestions?
Andrea
Rahul_S_Intel1
Have you tried any of example design or you have tried from your own logic
andrecap
Hi Rahul,
Thanks for your reply.
we are building our own logic from scratch.
The FPGA is placed on a hardware board we are also developing.
I am writing into the registers from the Root Complex, and I can verify the CRA registers are written correctly through signal tap.
Is it possible that I am getting something wrong in the procedure?
Andrea
Rahul_S_Intel1
Hi ,
Taking the conversation to private
