FPGA Intellectual Property
Weird harmonic in FFT
A sin22k is generated using the NCO with 23 bit output. Then the set of data, fsin_o based on the criteria: posedge clock , out_valid is 1, enable is 1, and out_valid is 1 are feed to fft. Weird harmonic resulted.
May i the reason and how to solve this?
Pls explain in a simple way because i am new to this.
Thanks a lot
sorry. I have found out the problem. There is something wrong with my raw data.
